can huawei p8 work on pm network now?
OHOHO
Hi guys, I have a huawei p8 dual SIM card phone, just wondering if it works on pm network now. I used check the phone's IMEI on the main page, it says the phone should work on the network, but I heard pm doesn't have 2G gsm, but this phone seems to use 2G for calling. Any ideas? Thank you.
2 REPLIES 2
saukalra
I also find this website useful to determine if a phone would work on PM network:
http://willmyphonework.net/
It appears that all submodels of P8 (except ALE-TL00) will work on PM 3G network. Some submodels will also work on 4G/LTE network.
PBForMe
According to gsmarena both variants have 850/1900 on 3G so if yours also does it should work.
http://www.gsmarena.com/huawei_p8-7006.php
If you are waiting for PM to get 2G that will never happen, so if your model does indeed lack those frequencies on 3G it'll never work.
