11-17-2020 07:30 PM - edited 01-05-2022 05:27 PM
hi, I have 2 friends using Public Mobile. I can call their numbers before.
when I call their numbers, it asks me to leave the voice mail. while they can call me correctly. I can their numbers in the same address, I want to fix this issue in person. the other phone is in service!!!!
what's the issue with my phone service?
I can make calls to other numbers out of Public Mobile network.
and I can make calls to another public mobile user also.
could public mobile do the health on the system?
The problem is fixed!
No more reply and discussions!
thanks for all your helps!
11-17-2020 10:01 PM
11-17-2020 09:54 PM
After carefully investigation, it is true that the other party carelessly blocked my number, just made a mistake!
After changing the settings, everything works fine now!
thanks!
11-17-2020 09:51 PM
@xbq wrote:the problem is fixed!
no more reply or discussion!
thanks!
Hi @xbq nice to know that the problem is fixed. Good for you!
It would be nice if you go the reply that helped you the most and click ‘Accept as Solution’ on the response. It will help other customers who are having the same problem. thanks in advance.
Stay safe!
11-17-2020 09:48 PM
11-17-2020 09:46 PM
thanks!
11-17-2020 08:08 PM
Well in that case, @xbq, it would seem your only recourse is the moderators.
I'm sure they'll be able to figure it out - they always do.
11-17-2020 08:03 PM - edited 11-17-2020 09:47 PM
11-17-2020 07:54 PM - edited 11-17-2020 09:50 PM
No!!!
I called 2 PM numbers, with the same wired issue.
and I called 3rd and 4th PM numbers, working fine.
all these friends are referred to PM by me, I know them. they never block numbers!
11-17-2020 07:52 PM - edited 11-17-2020 09:49 PM
No blocking!
I already contact the admin to investigate this wired issue!
11-17-2020 07:48 PM - edited 11-17-2020 09:38 PM
11-17-2020 07:44 PM - edited 11-17-2020 07:44 PM
@xbq stop wasting time in here and contact customer support... I have already provided you with a link on the first page
11-17-2020 07:42 PM - edited 11-17-2020 09:49 PM
Only my Public Mobile number has this issue.
If I can using other IP phones to their PM numbers, working fine!
and my PM number can make calls other other numbers both inside and outside of public mobile network
11-17-2020 07:40 PM - edited 11-17-2020 07:43 PM
@xbq wrote:only my PM number goes into the voicemail.
If i call with other number, working fine
Check to make sure they are not blocking/rejecting your PM number.
11-17-2020 07:40 PM
No.
The two numbers have been in the Public mobile for a while, not porting the numbers now!!!
11-17-2020 07:39 PM
No
11-17-2020 07:39 PM - edited 11-17-2020 09:51 PM
No, I am not in their block list.
I just prove it with them face to face!
11-17-2020 07:38 PM - edited 11-17-2020 09:51 PM
11-17-2020 07:35 PM - edited 11-17-2020 07:37 PM
Sounds to me your 2 friends have a setting on their phone enabled for calls to go directly to voicemail.
The question is, are all callers to them from other people going to voicemail, or just calls from you?
11-17-2020 07:34 PM - edited 11-17-2020 07:34 PM
@xbq ask your friends to check if you are on their call block list
contact customer support mods to investigate
make sure to check your inbox(top right corner envelope icon) periodically, for a response
11-17-2020 07:33 PM
11-17-2020 07:33 PM - edited 11-17-2020 07:36 PM
@xbq wrote:hi, I have 2 friends using Public Mobile.
It is not your PM service.
These two friend are in the middle of porting their numbers to PM.
You will get their voicemail until their old provider release their numbers to PM.
Both of your friends are at the stage 2 porting their number to PM.
FYI - Number porting is a 2 stage process:
Stage 1. After submitted your porting request, PM set up your old number on your PM account. Login to your account. Select the [Plan and Add-Ons] tab. Is your old number showing on the [Plan and Add-Ons] page?
If yes, PM has done its work to setup your old number for you to call out, send text and data.
If no, you should create a support ticket for moderator to investigate. Moderator wait time is from couple of hours to couple of days.
Stage 2. Now, you are waiting for your old provider to release your number to PM. Not until your old provider release your number, all the incoming calls and texts will continue to go to your old provider. You can continue to use the old provider SIM card until it stops working which is the indication that your number was released to PM.
