call log
Amanda23
is it possible to get a list of calls from a specific number
@Amanda23  You can check your usage history in over view page of your account . But it will only go back 90 days
Chalupa_Batman
If you log into your account and go to Subscriptions and add ons, look at Subscription Usage. View Usage History.
HI @Amanda23
PM support cannot help with that,
But you can login My Account and go to Usage log and go through each page to look for the phone number. Max on the log is for 90 days only. And sorry, download log does not work (only shows couple days) , you have to go through each page for the full 90 days to look for the number
@Amanda23
Just login to your account and look under Usage and it will all the calls and data you used.
