02-24-2023
03:22 PM
02-24-2023
11:03 PM
computergeek541
If I change my Ontario number to a Quebec number, can calls to my Ontario number be forwarded to my Quebec number automatically? If so, for how long?
Service
02-24-2023 08:35 PM
@benfatto wrote:The moment you change to a PQ number your Ontario number is permanently deactivated.
...until the old phone number is re-farmed to a new customer. 😉
02-24-2023 05:27 PM
I am checking this out....sounds like it might work
02-24-2023 04:41 PM - edited 02-24-2023 04:41 PM
@Traveller what are you trying to do?
Would you consider using VoIp app for the Quebec number?? Download TextNow and pick a Quebec number. Peoplw call your Quebec number and your VoIP app will ring. So you get 2 number the same time
02-24-2023 04:36 PM
@Traveller What you suggest cannot be done. The moment you change to a PQ number your Ontario number is permanently deactivated.
To do as you suggest, get a PQ number from https://www.fongo.com. Then forward your current number there.
- Fongo has free calling in Canada over wifi or cellular data.
- Setup voicemail to email on Fongo to receive notification and copies of voicemail wherever you are.
02-24-2023 03:48 PM
Nothing will happen. Calls to an inactive number can't be completed.
02-24-2023 03:29 PM - edited 02-24-2023 03:36 PM
@Traveller Yes or get a dual sim phone
adding or a phone that supports esim and get the new Quebec number with provider that supports esim and keep public mobile SIM card in the tray
02-24-2023 03:29 PM
very helpful advice but to do that, won't I need two telephones....mine only takes one sim card
02-24-2023 03:27 PM
@Traveller @If you change Ontario number to Quebec number the Ontario number is no longer … but if you keep two numbers you can call forward one number to the other indefinitely until you disable call forward
02-24-2023 03:27 PM
cannot risk losing the original number....it is essential to remain connect to people in many countries
02-24-2023 03:23 PM - edited 02-24-2023 03:25 PM
No, changing numbers abandons the old number.
Adding - but an interesting test. Just before selecting a new number, set up call forwarding to that number. Then let it go. Then see what happens and for how long.
