call forwarding minutes?
danijel
Is there a limit to the number of call forwarding minutes in the plans? Is it using your incoming minutes or outgoing minutes?
dabr
If you are on the limited plan minutes and are worried about using the call forwarding  because it will deduct from your outgoing minutes, you should consider purchasing the $5/500 Canad wide minutes add-on.  The add-on minutes don't expire and will roll over until depleted but can be whenever a limited plan minutes are completely used up.
Also don't forget to add the free 1GB and 400 int. LD mins being gifted by PM (if you haven't already).   The LD mins can also supplement limited plan mins in addition to being used for  making calls to the list of LD countries.
cellphoneuser1
It's unlimited to Canadian numbers if you have a Canada-wide unlimited talk plan.
Dunkman
@danijel
It will use your outgoing minutes.  So, if you have the $10 or $15 plan, it will count as your minutes.
