boxing week plans
619316
Are the boxing week monthly plans permanent forever? For example 4g speed for 29$ per month with 30 gbs of data will last for how long? is it forever?
Chalupa_Batman
Hey @619316
The $29 30GB plan is pretty decent. Just know though, once you use your 30GB of data, you get no more unless you pay for it. If I may suggest, you may want to consider the $34 plan as it's 50GB at 5G speeds and unlimited data at reduced speeds after 50GB. Just saying $5 more you get 20GB more data at full speeds then unlimited afterwards compared to stopped at 30GB. Something to consider IMO. Much better value for your dollar.
619316
thanks a lot
HALIMACS
Likely yes.
Once you’re in it, it’ll remain @619316
However once they’re no longer being offered, you’ll no longer be able to get em.
 ADDING:  Every 30 days, the plan will renew if you’re on auto pay and the 30GB data allotment will reset. Any remaining doesn’t roll over.
