08-27-2019 08:21 PM - edited 01-05-2022 06:42 AM
08-27-2019 08:44 PM
@davez1 wrote:@CS_Agent I bought the US roaming package and it's been consuming my plan data as well? That's not right, is it? Can I get a credit for the nearly 250mb of data on my plan? I just received an alert I'm near my limit. Thanks!
@davez1 What you are saying does not compute. If you are in the US currently then you cannot be using plan data uless you are at a border town. In that case manually set the mobile provider to be T-Mobile or AT&T. The fact that you received a usage warning text message today could be because it was delayed. Once selfserve is up go into your usage history logs and verify that data was used when you were in the US. Instead of tagging the moderator better to contact them directly if you still feel that there is an issue.
To contact Public Mobile click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
Moderators are available: M-F from 8 AM to midnight Eastern time and S-S from 8 AM to 10 PM Eastern time.
Note: Moderator Hours are subject to change, but you can always find the current times here
08-27-2019 08:34 PM
The 10 Day US Roaming Add-on is only for use whilst in USA. If you're still in Canada...you're using plan data.
08-27-2019 08:24 PM
@davez1 hi are you in canada? us roaming only works in the states
08-27-2019 08:24 PM - edited 08-27-2019 08:24 PM
@davez1 If you are in the US, you can't use your plan data. You can only use that while you are in Canada. Make sure you are not near the border and connected to Public Mobile/Telus network.
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
