blackberry
samfree
is model bbd100-2 compatible?
Staliger
@samfree Yes, this phone should work with PM. You are good to go.
Yes, BBD100-2 is a North America version, I believe.  It will work without issue
For your information,
Public Mobile uses the following frequency bands:
4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
HSPA: 850 MHz, 1900 MHz (UMTS).
4G = B2 (1900), B4/B66 (2100 or 1700), B5 (850), B7 (2600), B12/B17 (700), B13 (700), B29 (700-Suppl. DL), B30 (2300)
3G = B2(1900) B5 (850)
Triguy
Based on these specs it is compatible.
https://m.gsmarena.com/blackberry_dtek60-8351.php
Yes.
for public mobile phone compatibility
you have to put it a device brand for any phone to you can see all information,
you can visit here >>
WillMyPhoneWork.net - Check if your phone works on a network
following  >> To find out if your cellular phone is compatible with our network, click  HERE
Good Luck
