11-24-2023 06:01 PM
If I buy the 20GB at 5G speed, what speed will be considered the reduced speed after the 250 mb? I would think that all 20gb would be at 5 G. thanks
11-24-2023 07:06 PM
Thanks!!! now I cannot log in to buy it!!! PM's website is collapsed!!!
11-24-2023 06:31 PM
Hi @Tobi30 ,
Reading between the lines of your post, I think you may be slightly misunderstanding the speeds and amounts of that plan. The "250" figure is the (theoretical) 5G speed of the 20GB of data, 250 Mbps. After 20GB the speed will be 512 kbps (or 0.512 Mbps). So you are correct - the full 20GB will be at the 5G speed. Hope that helps.
11-24-2023 06:31 PM
512kbps (64 KB/s)
11-24-2023 06:26 PM
@Tobi30 , don't get the $34/20GB plan, be greedy and go for the $34/40GB plan. 😁
11-24-2023 06:06 PM
Hi @Tobi30
The speed after you use the data (provided you have unlimited) then you will get 512KBPS
