billing
NT31
I need a history of my billing and payments for 2023
8 REPLIES 8
NT31
Hi hairbag1, what I am presented with is different than your picture - when I click on payments I only get one narrow panel with the date of upcoming payment due... no drop down / no other fields... I am frustrating dealing with Public because of the inconsistencies I keep stumbling on.
Also every time I sign in I have to enter a code from my phone even though I clicked this is trusted device multiple times - it just doesn't take effect
Thank you for all your help and support, it's this community that makes me stick to Public. have a wonderful evening.
@NT31
notice the picture I added to original reply...if you click on date range, then use the drop down that you can select dates back to the last 12 months.
NT31
Hi hairbag1, I tried but the payment option does not show history as your display, it only shows the upcoming payment amount and nothing else. Thank you
NT31
hi Halimacs, I tried but the payment tab does not show history, only the upcoming omount??? thank you
NT31
Thank you hairbag1, I will try it. have a wonderful day.
NT31
Thank you Halimacs I will try that. have a great day
HALIMACS
@NT31
recommend waiting until January to get the full year.
if you need it now, look at your usage, history and payment history and select the dates you require.
hairbag1
@NT31
if you log in to your account / Payment / Payment History...you can print that off.
added pic
