06-29-2021 02:37 PM - edited 01-06-2022 02:39 AM
I bought a public mobile for my grandson. It was as a pay as you go, but I would like to change that to automatic payment withdrawals. How do I do that?
06-29-2021 11:16 PM - edited 06-29-2021 11:17 PM
As @computergeek541 have noted, there are additional information other than the PIN to avoid SIM swapping.
06-29-2021 10:44 PM
@BKNS27 wrote:You will need to contact a moderator to have you with your email/password issue but you will need your PIN number to have it changed.
Much more than just the account PIN is needed to change the e-mail address linked to self serve. The security requirements for change the e-mail address in considerably more in depth, requiring the customers to some of the following: approximate activation date, last payment date and amount, last 4 digits of credit card number, frequently called phone number, etc.
06-29-2021 06:53 PM
06-29-2021
03:52 PM
06-29-2021
04:17 PM
computergeek541
I do know the email xxxxxxxxxxxxxxxx
edited by computergeek541: e-mail address removed
06-29-2021 03:28 PM
@Bloodbath do you remember which email you used for My Account? If so, try to use the Forgot Password link. you can try to put in any of your email address you might have used and see which one works.
If you really unable to figure out, you will have to open a ticket with Mod and they can sort it out for you.
(After you open a ticket with mod, please monitor your Community inbox, envelope on the top right. Mod will communicate with you via messaging within Community)
1. For faster response (2 to 48 hours), Click on the bubble in the lower right corner and request moderator assistance, or you can also use this direct link instead https://publicmobile.ca/chatbot , then type "Submit a ticket", select Account-specific issue, then select I need a human now. Follow the prompts to submit a ticket.
2. Or you can Send a private message to the moderator here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
06-29-2021 03:11 PM - edited 06-29-2021 03:14 PM
who Create Account for you ask them which email they put it and password.
and if them don't know,
i suggest you Have To Submit a Ticket To Customer Service by Moderator Team,
Only one way to solve your issue , explanation to customer service by Moderator Team
and the are nice service Team the will help you 100%.
Here’s how to contact customer service by Moderator Team,
Good Luck
06-29-2021 03:11 PM - edited 06-29-2021 03:11 PM
Did you activate the sim card in store or online? If online you have already created the self serve account and must use the email and password you registered during activation. If you activated in store you must finish creating the account by using the phone number and have access to the phone to recieve the 6 digit alphanumeric code to complete the self serve account set up.
06-29-2021 02:50 PM
Try using a different browser and incognito mode. Also try clearing your cache and cookies then reboot.
06-29-2021 02:48 PM
I have tried to get on self serve but it will not accept my email address that I bought the phone with
06-29-2021 02:42 PM - edited 06-29-2021 02:45 PM
when you sign in to your Self-Serve account, you can or won't let you singe in to your account,
i suggest you can try it for a different Browser
and clear cache and cookies for any Browser,
and use a Browser from your computer,
and just make sure your Browser is up to date update
sometime is the Browser is not update is give a issue.
and Restart your computer, is will help.
and if you use a home internet please do one thing take it your power internet for about a minute and put it back, Restart your device is will help,
just make sure your credit card number and your address match the same one ,
your typing and sometime you type it but is a one word or letter or number is a wrong or is missing just make sure for it.
06-29-2021 02:39 PM
I tried to get on to self serve but it won't let me
06-29-2021 02:38 PM
Set Up AutoPay
Setting up AutoPay means that you earn $2 every 30 days!To set up AutoPay, sign in to your Self-Serve account, select the ‘Payment’ tab, then ‘Register for AutoPay’. From here, you can sign up for AutoPay or remove the feature, if you no longer want payments to automatically occur. If you would like to change the card that is automatically charged, scroll to the bottom of the ‘Payment’ tab, then select ‘Manage my card’. This will allow you to update or remove your credit or Visa Debit card.
