authentication
Inclusive
Please help stop the two way verification when signing in.... the bookkeeper has to hunt for a verification code to log into account for invoice. Pm is not recognizing computer on log in.
@Inclusive
Sorry, you can’t disable the 2FA code for your own safety of SIM swapping.
Your accountant can login to a specific laptop or computer and click on trusted device. That works most of the time.
Yummy
There is no way to stop 2 way verification when signing up. This was implemented for 'your safety'.
Even if you say it is trusted computer it might continue sending a code.
There is nothing to hunt for. Code is sent as SMS or if you chose through email.
I occasionally get that code but Not every time I sign in. Maybe you delete cookies every time you close your browser?
dust2dust
I highly doubt they will remove 2fa. The bookkeeper could use a different, not used in eversafe yet number to send the code to. But only once. If the bookkeeper has other accounts to manage then that starts to become cumbersome. But then you would have your different needs to log in to your account yourself. Like the email option. Which the bookkeeper could also use by clicking on the didn't get code link.
I have little to no faith in the remember device option.
