Authentication code goes to wrong phone number
hsrussel
Hi
The authentication codes are going to a previous phone number, not the number I have now. How can this be corrected?
Regards
Hasnat
hsrussel
Thanks changing Eversafe ID worked.
hsrussel
hsrussel
Thank you. I am doing that but that does not solve the real issue.
Rastin
Under where you enter the code you should see did not get code.  Click on it and you can have the code sent to your email
Phil_Adelphus
@hsrussel   Log in to your account by selecting "didn't get the code" which should give you the email option.  Once you are logged in go to your Eversafe profile and edit the phone number there to change it to your current one.
@hsrussel  Do you see option says “ didn’t get code “ tap it and you should get option to send code by email and update your number in your profile page manage ever safe ID
but if you cannot log into bet support to help fix for you
send  a  private message   To CS_Agent
