addons
04-01-2022 09:54 PM
Why I just after added 1gb of data in addons I got a text message saying that I have already used 75% of my data? I want my money back
Add-Ons
04-02-2022 08:28 AM
@hairbag1 wrote: I wonder if the message you got was to remind you that you've used up 75% of regular plan data...not add-on data.
@hairbag1 @mariomdiaz I receive warning messages when I get close on plan data but never for the add ons, gifted or purchased.
04-01-2022 11:30 PM
@mariomdiaz wrote:Why I just after added 1gb of data in addons I got a text message saying that I have already used 75% of my data? I want my money back
Log in to your account / My Data and add-ons to see how much you've used.
04-01-2022 10:47 PM
Hi, Log into your account and check your usage on the 1gb you purchased. If not used, it should still be there as a line item and not 25% unless that was accidently used.
I once accidently used a load of data up with phone app updates instead of make it use wifi.
04-01-2022 10:08 PM
It is likely an errant text message. Always refer to your overview page for the most accurate data usage reading.
04-01-2022 10:06 PM
Go by what your account says, many seem to get this 75% text in error and the meter in your self serve account is accurate.
04-01-2022 09:57 PM
@mariomdiaz If you login to My Account, under My Data & Add-ons, do you see the 1GB data you just bought? If not, check if you see any money there as Available Fund on My Account. If so, is there $15 in Available Fund? Buying amount is a 2 steps process, 1. Add Fund, 2. Buying of the addon. Some people just loaded the fund into Available Fund and not aware they need to do step 2 to complete the purchase
