add unlimited us roaming plan
Rabbi
hi @Brooke_C
i think that you should add a new plan with unlimited us roaming in the plan for the entire month
srlawren
@Rabbi cannot see that happening
Rabbi
@koimr1 wrote:
@Rabbi wrote:
hi @Brooke_C
When you say "unlimited" are you talking about talking/texting or data? Or both?
all options
talk only
text only
talk & text
talk & text & data 3g
talk & text & data 4g
koimr1
@Rabbi wrote:
hi @Brooke_C
Korade
I don't think that even the big carriers have an unlimited US roaming option. In any case, like mentioned above, it would be very expensive.
If you visit the US often, you might be better off signing up for an unlimited plan (or something like that) down there. They even have unlimited roaming in Canada, but there are certain conditions. Good luck.
Korade
@srlawren wrote:
Sorry @Rabbi, I just don't see this happening.  Or if it were offered, it would likely be extremely expensive.
+1. This suggestion is effectively saying Public Mobile should be a US carrier.  This ain't ever going to happen.
srlawren
