Data issue
05-24-2018 04:04 PM - edited 01-04-2022 06:01 PM
I am new to public mobile. I signed up for 5GB of data and already the data isn’t working. I don’t know how to find out if I’ve used it all but I have never used 5GB before when I was with Telus so I don’t see that as an issue. I cannot use any data or apps unless connected to wifi.
Joining Public
05-24-2018 05:46 PM - edited 05-24-2018 05:47 PM
@Korade wrote:What do you mean "shows everything"? Does it show your minutes/texts sent?
Which phone do you have btw? Try entering the IMEI number here: https://www.publicmobile.ca/en/on/get-started to ensure it is compatible.
OP said iMessage, so it should be an iPhone. afaik iPhones should work fine on PM.
OP, have you tried the steps in this knowledge base article?
05-24-2018 05:31 PM
05-24-2018 04:40 PM - edited 05-24-2018 04:41 PM
a) What model do you have?
b) Check for a carrier update: Settings >> General >> About: if a carrier update is offered install it. Then reboot.
c) Do a network reset: Settings >> General >> Reset >> Reset Network Settings: you will need to reinstall wifi passwords after this.
d) Confirm Cellular Data is ON.
e) Do you have a 3G data plan, that just renewed?
05-24-2018 04:15 PM
Thank you, yes my calling and texting works if I send as text.. but not the iMessage.
I logged in and tried viewing my usage but I don’t see a “number” for data usuage. It just goes to usuage review and shows everything.
05-24-2018 04:10 PM
Hi Courtneeyw,
Some troubleshooting:
Is your calling/texting functioning alright?
Log in to self serve and you can view your usage for data. It should be pretty much zero, if you haven't used any.
Lastly, is the data option on your phone turned on? Does it say LTE/3G somewhere by the signal?
Turn your phone off and on after installing the SIM card
If these don't work for you, get in touch with the moderator team!
