06-26-2022 11:47 AM
I bought the wrong add-on. How do I correct that and get reimbursed?
Add-Ons
06-26-2022 05:13 PM
This would be the best option, you cna either put it towards the right add on or a future renewal
06-26-2022 12:00 PM
Contact Customer service agent as described above. It will take several hours for response. In general, since Public mobile is prepaid, there are no refunds, but CSA usually will credit your available balance. You can use the available balance for another add on or future payments.
06-26-2022 11:51 AM
hello if you will need to contact a cs agent
1.you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
