add on usage
Samhorns
  • I already finished using my data plan this month as I continue using data it doesn't seems to use my add on bonus see attachment why?Screenshot_20230608-120204_Chrome.jpg
@Samhorns  Try this
Try again incognito/private mode
And or lap top /computer
                    OR
simply try refreshing the page to check data plan / mins / add ons
@Samhorns
Refresh your browser by clicking on the circular arrow. It might be on the previous login.
@Samhorns call 611 to check the data remaining in your account. If this is a cache issue and you do still have plan data left, this should tell you. Note, 611 tells you what is remaining in your plan and addon data added together.
HI @Samhorns   so you are using data but not count?  no, won't be that good
possibly the browser cache problem
Click the refresh spinner on the lower right if you see it
if not , please login again using Incognito/Private/secret mode to avoid browser cache, wrong info
