add on minutes
03-25-2024 10:24 AM
i added on 500 Canada wide minutes to my plan. Do they go into effect right away? How do i know I have these extra minutes without running out first?
Add-Ons
03-25-2024 11:48 AM
@Yummy wrote:As I know, minutes do NOT expire in 150 days.
This was my understanding too. Unless they've changed this on us as well. I went through the fine print, most of it is very outdated. I just purchased one of these and it didn't tell me anything about an expire date. Therefore, there should be no expire date on those.
03-25-2024 10:30 AM - edited 03-25-2024 10:33 AM
Yes, add-on should become active right away. Refresh PM page to see it on your account.
As I know, minutes do NOT expire in 150 days. ONLY loyalty reward data expires in 150 days.
AND data add-on expires in 30 days.
03-25-2024 10:28 AM
Thank you very much for that quick reply. That helps a lot
03-25-2024 10:26 AM
The way add-ons work is first your plan minutes are used and if they completely finish them then that’s when your add-on kicks in. Keep in mind they expire is 150 days so be sure to use them so they don’t expire.
