activation
11-21-2022
09:33 PM
11-21-2022
10:20 PM
computergeek541
activated account and paid for first month. public mobile will not come up on iPhone 11. previous provider was Telus through work. how on earth do e get public mobile to come up? have been turning phone off and on to reboot for 24 hours
Joining Public
Phones
Service
11-21-2022 10:45 PM
You mentioned that you ported your Telus number over.
Did you leave your Telus sim in your phone to receive the confirmation text from Telus to port your number out?
11-21-2022 10:24 PM
I did direct message customer service, thanks
11-21-2022 10:17 PM
OK that is. the problem, we need the CS_agent to port manually. how do I PM the CS agent?
11-21-2022 10:14 PM
Because Public Mobile is part of Telus, if you are porting from Telus (or Koodo another sister company), a CS_agent needs to do the port manually.
Send a PM to CS_agent.
11-21-2022 10:08 PM
we did port the number over. how do I reset in network settings? We have reinstalled SIM card a few times...
11-21-2022 10:07 PM
Thanks I submitted a ticket. no error message just nothing. seems strange as payment went through
11-21-2022 09:36 PM
@cjvg does it have an error "No Network" , "SIM not provisioned" or "No Sim"?
you tried the PM sim card on another phone?
it could be that the sim card was not provisioned properly. Open ticket with PM Support, It should be a quick fix, you just need to engage them via open ticket:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
11-21-2022 09:36 PM
Did you port your number over? Did you try resetting network settings, reinstalling SIM card?
Try sim in another unlocked phone?
