2 hours ago
i created a subscription to the 30$ plan with amazon discount so it was 15$ but when i login to account it says to contact support, i need help activating and transferring my number from kodoo
2 hours ago
hi @zanemalik did you use the app to activate? are you porting from Koodo Prepaid or Postpaid? if Prepaid, you need to get a new number first and ask support agent to help port after
if you need support agent to check, pleas message them here
2 hours ago
did you use the Amazon link to start subscription or did you put the Amazon discount code at Promo code at the payment step?
PM can help to apply it back if the system didn't take it for whatever reason
Just open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this link:
2 hours ago
Hello @zanemalik
Here is how.
To submit a ticket with CS Agent using this Chatbot link
Type Customer Service and follow the prompts. If you are having any issues, here is a direct link by sending a private message
Check your mailbox for their reply
