09-27-2024 05:31 PM - last edited on 09-27-2024 09:15 PM by computergeek541
I have bought a physical sim card and installed it but cannot activate it. Help
09-28-2024 03:28 PM - edited 09-28-2024 03:28 PM
09-28-2024 03:22 PM
I had to restart my phone and my SIM and messages came through. That might work?
09-27-2024 05:39 PM
at which stage you are at for activation? if you only use the web browser to activate and just got to the payment step, it is not done
you need to use the app to get to payment , thrn choose phone number and then the final activation step
or tell us more what you have done
09-27-2024 05:36 PM
Have you downloaded the app to start or finish setting it up? If so, what stage are you at that you're stuck at? We are going to need more info if we're going to try to help you.
