account suspended, then i made payment online, status became active but the phonestill not working
patng2222
account suspended, then i made payment online, status became active but the phone is still not working. I did restart the phone and insert the sim card again. It doesn't help.please advise
2 REPLIES 2
No fix you can do; it's an infrequent renewal bug. Robot Sad
Unfortunately you will need moderator assistance. Click this: message to moderators to send a private message to the moderator team with your phone number and an explanation. Check that email notification of private messages is turned ON to see their response as soon as it arrives.
Meanwhile, if you need to make phone calls try an application like that from fongo.com. It provides free calling across Canada from wherever you are connected to wifi.
Just for the info:unless your phone stops working ignore any suspension message that shows on your account near renewal. That is a messaging quirk of the accounting system.
kimka90
i need answer for this too!!!
