account pin
tropoja7
hello my name is Axxxxx Txxxx i need help with getting account pin how can i get that.
Edit by Dunkman: removed personal information
7 REPLIES 7
@tropoja7
The PIN is something you created while activating your SIM.
@tropoja7 yes, new activation now do not have PIN setup during activation.  You have to login to My Account after to setup the account PIN
@tropoja7
so are you suggesting there’s no option for you to set the PIN code by tapping on the pencil icon to the right of the field where the PIN is masked?
That doesn’t sound right.
But if it’s the case, contact one of the customer support agents for assistance in setting that up.
To contact a Customer Support Agent, send a private message to the Customer Support Agent by clicking here  You’ll need to be logged into your Community account for the link to work.
tropoja7
i never got the pin password before
Click on pen icon on the PIN password section to change your PIN password.
tropoja7
i open my profile but i don't see anything
HALIMACS
@tropoja7
Log into your self serve and you can create one there under your Profile settings
