04-15-2021 08:12 AM - edited 01-06-2022 01:47 AM
Hi, i had till today to top up my account before my account was permanently deactivated. Tried to login but can't. Please help!
04-15-2021 08:33 AM - edited 04-15-2021 08:34 AM
Was your number originally a telus/koodo/pm number? Then maybe....submit a support ticket and explain what happened and they might be able to retrieve it but if it came from another provider it automatically goes back to them.
04-15-2021 08:32 AM
What happens when you dial 611 on your phone? Is it possible that your plan is already deactivated due to inactivity. It is 90 days suspension before deactivation.
Have you tried reseting your password?
https://selfserve.publicmobile.ca/forgot-password/
(Check your junk folder)
If not working, you will need to contact moderator.
Click on the chat bubble icon on the right lower corner of website to start ticketing process to contact moderator. Type: Contact moderator. Follow the prompts to submit ticket.
You can also try dialing 611 on your phone to load up funds.
https://productioncommunity.publicmobile.ca/t5/Self-Serve/611-IVR-Menu-System/m-p/289352
If you are having difficulties accessing self service account and in a rush, the quickest way is to buy a voucher in store or online (recharge.com - service fee applies) and load funds by dialing 611.
04-15-2021 08:30 AM
Thanks for replying. If i get a new Sim can i still keep my number?
04-15-2021 08:29 AM
Did your account say top up before April 15th 2021? That meant you had to do it by midnight eastern last night. I don't think there is anything you can do about it. But you can try contacting the moderators. If you have to top up before tomorrow and you are having trouble logging in then you get the moderators to help....click on the chat bubble on the bottom right corner of your screen and submit a ticket via simon.
