a70
ezbake
m phone is not activating , cant register with network
11 REPLIES 11
@0077 wrote:
@ezbake
reset network settings and  Changing APN Settings
and reboot phone,
APN settings don't have any relation to a a cell phone device's base connection to the network.
ezbake
will do
HI @ezbake   glad we are on the right direction.  Come back and let us know when it is fully resolved.
ezbake
yah , i did that they found some issues in ativation so its them not me , thanks for help , waiting for tech ppl to fix
@ezbake wrote:
a70, worked on koodo , cant connect to network , havnt tried some pother phone to test sim
HI @ezbake   would be nice if you have another phone to test the PM SIM.  It could be a problem with PM setting up the SIM on the backend
if you don't have another phone to test, just go ahead and open ticket with PM and ask them to check :
Click on the Bubble or directly at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
  1. type: Contact CS Agent
  2. Click "Contact Us"
  3. Click "Other"
  4. Click "Click here to submit a ticket"
  5. you will then direct to another page to open ticket.
If you have problems submitting a ticket, you can also send a private message to the moderators (but this can take longer):
ezbake
was on chatr not koodo
ezbake
ezbake
hi, so i try to choose public mobile manually and get , cant register with network, used a70 but cant be locked its to new, new activation ,worked on koodo
HI @ezbake  It could be a SIM issue instead of the phone. Do you have another phone around and you can test your PM SIM on?
@0077 wrote:
@ezbake
check the status  Account Log In
what your device brand and model and provide more info ?
Check the Status of Your Device in Canada
HI @0077 did you even read?
Dunkman
@ezbake
The Samsung A70 is compatible with Public mobile.
More details would be helpful.
New phone?  used phone?  Did it work before?
New customer versus old?
Does the phone work with another SIM card?
Locked to previous carrier?
Blacklisted device?
