03-19-2022 10:59 PM
Hi,
I tried to sign in to my account but I could not. NMy SIM is working. What should I do??
03-19-2022 11:29 PM
03-19-2022 11:21 PM
Thanks, I sent the problem and I hope I got it solved
03-19-2022 11:15 PM
@Diala - have you tried the Forgot your Password option: https://selfserve.publicmobile.ca/forgot-password/
Remember to check your spam/junk email folder for the password reset.
If still issues contact CSA.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them:
1 - Faster - Click the bubble comment circle on the bottom right-hand side of your screen,
or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Contact Public Mobile Representatives (CSA) by submitting a message(ticket) to them here:
Private Message to Public Mobile Customer Support Agents (CSA)
03-19-2022 11:11 PM
How??
03-19-2022 11:05 PM - edited 03-19-2022 11:07 PM
If this has been a long-standing issue, and you have to be able to sign in before, perhaps your login credentials are incorrect.
Try contacting the customer support agents by sending a private message to them by clicking here
You’ll need to be logged into your Community account for the link to work.
03-19-2022 11:04 PM - edited 03-19-2022 11:04 PM
Yes, I have always signed in and bought plans since 2020. But this time not work
03-19-2022 11:03 PM
03-19-2022 11:01 PM
I have tried several times on different days. No working
03-19-2022 11:00 PM
The system may be temporarily down. It's best to sometimes wait an hour and/or try a different device or browser
