Zenfone 3 won't connect to network
Mikey68
 I have changed APN settings and were able to connect to network while my Phone"s wifi were on. Once I disconneted, the Public Mobile at top of screen disappeared! Iam baffled and any help would be greatly appreciated!
12 REPLIES 12
Hi @Mikey68 what regional varient do you have?  If you have a Global version or Indiab version, you would not have enough band connect well to the LTE networks  Only the Taiwan or US/Brazil version will work well
Your phone 8n all version should have the full compatible bands on 3G
  Try to lock your network type to 3G only and the data should work
Timer
@Mikey68
Asus Zenfone 3  what your model
Mikey68
I have done that to no avail. I cannot text nor make/ recieved calls. The Network is only on while my wifi is on. I cannot tell what version but had worked prior on the Chart Network? Still miffed!
Timer
@Mikey68
How to find model name visit here:   asus.com/support/FAQ/1014441/
dust2dust
This is all very confusing. Turn off all the radios except cell. Wifi off, bluetooth off, nfc off (if present), location off, mobile data off. Even force close any fm radio app. Can you call and text?
Turn on mobile data. Can you get to a website?
Turn off mobile data and turn on wifi and connect to your home internet assuming you have it. Can you get to a website?
Can you set your Preferred network type 3G or LTE or at least both.
Timer
@Mikey68
1. How to Reset Network Setting
2. select your device model to get customized  APN Settings
3.  Switch to 3G network.
and rebooting device.
if still not working  do Hard Reset, and you need to backup before you do that to save videos/photos/contacts.
I recently did a factory reset. This is absolutely last resort. Backups are unreliable and incomplete.
Mikey68
It's Z01HD
Mikey68
No luck my friend,I have also changed APN several times
