08-22-2017 01:58 PM - edited 01-04-2022 02:33 PM
Hey never got this to work and now it's bugging me.
Have a ZTE Axon, everything works like sending text and recieveing but I'm unable to send or recieve picture messages.
Heres a screen shot of my one and only APN
08-22-2017 03:28 PM
@drgonzo905 Try these ideas:
08-22-2017 03:24 PM
Is your data working?
Are you on wifi when you tried to send the sms? Some phones need to be on data and not wifi in order to send MMS.
08-22-2017 03:09 PM
Hi.
Here's something that might help
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
APN Tethering Settings:
Name: Tethered Mobile Internet
APN: isp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMSC: Not set
MMS proxy: Not set
MMS port: Not set
MCC: 302
MNC: 220
APN type: dun
APN protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
08-22-2017 02:03 PM
Hi drgonzo905,
Thank you for reaching out to us.
According to your screenshot, it seems that you have put well the MMSC address to http://aliasredirect.net/proxy/mb/mmsc which should allow you to use the MMS service. Also, I'd suggest you to update your android software version to the most recent one and contact your phone manufacturer for more technical supports.
Have a nice day!
Cheers
Abdoulaye
