11-30-2016 11:03 PM - edited 01-04-2022 01:20 PM
Just setup an Axon 7 this evening. Everything was read correctly from the PM SIM card except one field.
MNVO value was initially set to 50 and the LTE data would not connect.
Change MNVO to 4D4F and LTE started working right away.
This thread also highlights the importance of this field.....
10-06-2018 02:39 PM
THANKS ALOT!!!
you solved my misery!!
11-30-2016 11:14 PM
@imcphers wrote:Just setup an Axon 7 this evening. Everything was read correctly from the PM SIM card except one field.
You can leave MVNO type blank and that works also. If MVNO type is not specified, the MVNO value is not required.
