02-11-2025 04:25 PM
Hi, last night I bought a plan with you guys, wasn’t to familiar with the eSIM stuff yet I noticed in my settings my phone has and IMEI and IMEI 2, I only put the first one in when registering not knowing IMEI 2 needs to be used to eSIMs. I don’t know how to update it, need help pls.
02-11-2025 07:56 PM
What is the make and model of your phone?
If you go into Settings>Cellular…it should show Add eSIM if it is a new iPhones.
02-11-2025 04:57 PM
Then ask PM to help
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
02-11-2025 04:55 PM
Still isn’t working I’ve tried
02-11-2025 04:27 PM
You dont need to enter IMEI number when you install esim, it will install on the correct slot
What you see in your sim manager screen? You just need to enable it, then reset network settings
(And make sure old sim card is removed, or old esim are disabled)
