“Your eSIM could not be installed”
teddy1997
Hello,
I transferred to Public Mobile yesterday and kept my old phone number. I followed all the instructions when downloading the eSIM and even had data at one point. However, after the transfer and old provider deactivated, my Public Mobile eSIM is no longer working and shows “SOS” where the signal bars are. I’ve tried everything including resetting Network settings and still did not work. I have also messaged support and still no response after more than 4hours. Any advice?
Frank52
This will require a ticket to Customer Service using the following link. Please write to them and explain your issue. They will eventually respond and resolve your problem. The response times are very long at the moment (1-2 days) so please hang in their and practice patience.
In the meantime, you can review the following articles to see if you followed the steps correctly. It might help with the Esim issue:
https://www.publicmobile.ca/en/get-help/articles/transfer-your-number
Additionally, here is a ESIM FAQ document:
https://www.publicmobile.ca/en/get-help/articles/esim-faqs
jluong1
@CS_Agent should hopefully get back to you and resolve this soon.
You can also try getting a new esim or physical sim to fix your issue.
teddy1997
I can log in on the app, but I want to keep my phone number and I’m worried that would mess it up if I buy a new eSIM. Is it possible to transfer the same number on the new one if I buy?
hi @teddy1997
can you login PM app on the phone? if you can , a quick way is to buy a new esim from Account page on the app (Purchase sim card and choose esim)
if you cannot login , then you will need to ask PM to help.  you can submit  ticket by direct message:
