12-25-2022 02:29 PM
Hello, my wife's email is connected to my number account. I'm now having a personnal email and I would like to change the email of my account. How can I do that? Thank you.
My Account
12-25-2022 02:35 PM
HI @framboiselev Only PM CS agent can help to change email address for My Account.
Please open ticket with them
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
12-25-2022 02:34 PM
Only agent can change your email.
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
12-25-2022 02:30 PM - edited 12-25-2022 02:30 PM
You need to contact customer support, @framboiselev
Here's how to contact a Customer Support Agent; there are 2 methods:
- Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request). Click the result which states Click here to submit a ticket and follow the prompts, or,
- Send a private message to the Customer Support Agent by clicking here You’ll need to be logged into your Community account for the link to work.
