12-25-2022 02:43 PM
Both my spouse and I are on PM and we both have not had cell service since Friday evening around 7pm Dec. 23 -2022. All efforts have been exhausted to restore things from our end, rebooting, removing SIM cards and rebooting, etc. When I drove from where we live (Port Burwell ) on Saturday, I had service once reaching another town. Coming back home I was again without service.
The only change in the last 40 plus hours has been that previously I had simply “no service “ whereas presently, since this morning, I now have “emergency calls only”. Add this to the fact that our hydro has been out for even longer and it is Christmas, it’s very much a problem. I needed to have a friend create a wifi connection just to do this and won’t have this option for long.
please help.
Kris Backs
12-25-2022 03:22 PM
Thanks you all for the replies. I am in full agreement that the weather has been wreaking havoc on communication infrastructures. I had previously looked to see if this was a reported outage listed under PM and found it was not, however when following a link provided by @Meow I found this was indeed on their radar and is listed under Telus errors.
I went ahead and submitted a ticket anyway. Thanks again
k
12-25-2022 02:51 PM
12-25-2022 02:51 PM
@krisbee according to Telus outage page there, is a
Failure of Wireless and Wireline Services in Eastern Canada
Start Time: December 23, 6:00 AM
It could be why you don't have your service where you are.
I suggest you to open ticket with PM Support and log your situation first, they can look up , confirm or send technician over to check if needed
Just open a ticket via Chatbot for PM Support :
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
12-25-2022 02:46 PM
In your case, most likely local cell tower is not in service.
You can check one of thee sites but if it is minor disruption outage might not be reported here.
