05-15-2023 08:01 AM
Hello all,
I travelled on business to the US last month and paid for the one-time US roaming add-on using my work credit card.
I am set up on Autopay and found out this morning that my work credit card was just charged for my monthly bill but I need to use my personal credit card for my monthly bills. I didn't realize that the one-time US roaming payment would automatically switch over my Autopay settings.
I've switched the settings to use my personal card going forward but I need to undo this morning's payment on the work card and put it on my personal card. How can I do this?
05-15-2023 08:37 AM
@johnnythejames - I would suggest you do a payback to your company in this case; just explain to your employer. Hopefully it should not be an issue. It may be easier and quicker for your purposes here.
05-15-2023 08:07 AM - edited 05-15-2023 08:08 AM
@johnnythejames I am not sure they can do it
What I suggest is to update the credit card back to your own on your My Account first.
Then open ticket with PM support and ask them to take a payment amount from your own credit card first, and see if they can then reverse the transaction from your work credit card
To open ticket with PM support:
1. Please open ticket via Chatbot (requires access to My Account) using direct link: https://publicmobile.ca/chatbot.
Start by typing "Contact agent ", then click "Contact Us", then click "Other", click "Click here to submit a ticket ↗""
Next, enter your Community login, then enter your question. Finally use My Account login or 4 digits PIN to validate.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
