Wrong addon
brendanicholson
I mistakenly added a US data add on how can I redeem my money?
1 ACCEPTED SOLUTION
Accepted Solutions
RossN
@brendanicholson
hi for a refund get in contact with a cs agent
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
RossN
@brendanicholson
MrSpock
@brendanicholson
hi  you can contact  a cs agent explain your problem  Click here or if you are having issues with Simon you can send private message to a CS Agent here:  https://bit.ly/2GGCJzH
@brendanicholson
Just open a ticket with PM Support and they will reverse the transaction for you and put the money back to My Account for other use, maybe future renewal
to open ticket :
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
brendanicholson
Thank you
