Wrong Add on chosen, want to revoked to the US 1000 mints add on
Saurav7986
Hi,
I have chosen wrong add on subscription
I want to add on the US 1000 mints and I have selected US roaming text and talk
is there anyway some one can help me to get the US 1000 mints instead of roaming text and talk
it’s very urgent and I don’t have the money to spend again . Please please help me!!
Thanks
@lantz wrote:
I must have added a add on by mistake I want it deleted
HI @lantz
you will need to ask support agent to help.  They will likely reverse it and add the credit back to your account as available funds
 please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
lantz
HALIMACS
Just so it’s clear, @Saurav7986 , you’re wanting to call FROM CANADA to the USA?
Indeed the customer support agents will likely credit the incorrect add-on so you can select the one you desire.
Another option, however, is to download WhatsApp, or another calling app, and you can call for FREE to the US from Canada.
 All you need for that to use is to be in wifi or have mobile data enabled.
Hollister
@Saurav7986
  • you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work.
During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
  • Monday to Sunday: 9 AM to 10 PM EST
Keep an eye on the envelope icon in top right hand corner for a reply from the agent.
