3 hours ago
The app is down and I can't activate my account after I just paid it said to go to the website to activate and when I go to the website it says to go to the app
an hour ago
Just try it again the app is working and I am all set thanks for your help
2 hours ago
Thanks I have submitted my response to them
2 hours ago
please use the link I provided above to message support for help
2 hours ago
2 hours ago
did you try to logout and log back in using the app? If you are really unable to use the app to proceed to the final step, you will need support to help. Please message them here:
