Winback Promo not working
StavrosC
Hi,
I'm trying to resubscribe with the Winback code, but it keeps on giving me an error when I try to apply the code. Some help please?
CSA_PM
Customer Support Agent
Thank you for bringing this to our attention! The customer was already in a private conversation with one of our agents when the post was escalated. The agent will continue assisting them directly.
@StavrosC wrote:
Yes it was a direct email and code from PM, and I did that, and kept on giving an error
hi @StavrosC
I assume you are using the code before it is expired?
ask PM support agent to check and confirm what went wrong.  You can submit  ticket by direct message:
StavrosC
hi @StavrosC  is that a Winback offer from PM? what was the terms about ?
usually, you need to put in the code at the Payment step, there is a box for Promos code.   Did you try there?
slusagm
ask PM to check and they can help.  Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
