Will my add-on expire if not used?
Lachlan_M
Retraité / Retired
Retraité / Retired
Add-ons will not expire if not used.
Acekiller
mine has not expired and i got it 3 months ago.  moderator is your best bet.
srlawren
@Mboik you should contact a community moderator for assistance.  If you're not sure how, check out the two links in my signature at the bottom of this reply.
It absolutely is true.  I have an LD addon I haven't used any minutes in yet, that was applied to my account in September, and is still there 5 months later.
either you have had an error occur on your account, or you've exhausted your addons already.
Mboik
This is not true.. Mine seem to have disappeared. I bought them 2 months ago and haven't carried over
