06-04-2025
01:04 PM
06-04-2025
01:38 PM
computergeek541
anybody know if public will offer wifi calling soon. Service is poor in my house especially in the computer room where most of my calls are made. If they are not then i will have to seriously consider changing providers like to Freedom mobile that is equal to public
06-04-2025 01:44 PM
hi @pvlarry
no Tier 3 carrier offers Wifi Calling, I don't see any chance for PM unless there are other carrier start offering that
06-04-2025 01:34 PM
Last time that I asked PM staff (about 6 months ago), Wifi calling was not being considering as a feature. So, I don't think that PM will be offering Wifi calling anytime soon.
BTW, which model phone are you using? If not VoLTE compatible to PM network, then getting a newer phone might make a difference.
Otherwise, some customers had to leave Public mobile due to the lack of this feature.
06-04-2025 01:12 PM
@pvlarry wrote:anybody know if public will offer wifi calling soon. Service is poor in my house especially in the computer room where most of my calls are made. If they are not then i will have to seriously consider changing providers like to Freedom mobile that is equal to public
I do not think Public Mobile will ever offer WiFi calling. However, there is something you can try and see if it works. Go into your Settings, then Network Settings and then reset your Network Settings and reboot. See if that helps. If not, then go back in to Network Settings and turn off automatic and pick Public Mobile. See if the signal is better. If not, see which other options you have there such as Bell. Try that and see if it's better reception.
06-04-2025 01:08 PM
As customers we have no way of knowing if and when PM will offer Wi-Fi calling. If you need it now, I would port out and if they offer it in the future you always have to option to come back.
