WiFi Calling
bucket
I have the same problem with phoning in my house. WiFi Calling doesn't seem to be available with Public Mobile
2 REPLIES 2
TheSterlinger
Sorry this is not an option at Public Mobile.  You need Koodo or Telus ornothers for that.
Chalupa_Batman
I'll repeat what I said to the other person.
I do not think Public Mobile will ever offer WiFi calling. However, there is something you can try and see if it works. Go into your Settings, then Network Settings and then reset your Network Settings and reboot. See if that helps. If not, then go back in to Network Settings and turn off automatic and pick Public Mobile. See if the signal is better. If not, see which other options you have there such as Bell. Try that and see if it's better reception.
The only options that have WiFi calling are Koodo or Telus.
