03-22-2015 09:59 PM - edited 01-04-2022 01:15 PM
Whenever I receive a call, it displays 011 followed by phone number. Wondering if this is with phone or from Public Mobile itself.. In turn, when I dial the number displayed does not go through because of 011 being there.
10-31-2017 05:01 PM
They are routing their calls through different country codes to try and get people to answer. The calls are from Capital One credit.
03-23-2015 08:52 AM
This is hapening because of your phone settings, Go to Settings/Location and Set location to on,
Go to Language & Region/Country region and set Country to Canada that will avoid dialing the 011 code
03-23-2015 12:06 AM
03-23-2015 12:04 AM - edited 03-23-2015 12:09 AM
@Martin No, none of my contacts start with 011. There are other country codes, like +44 for the UK, +61 for Australia, etc. Contacts on my phone have always shown up like (555) 555-5555. But then again, 555-555-5555 is the same thing, written differently. I've also noticed if I call from Vancouver to Toronto by directly dialling the number - 4165555555, I hear a "Please stay on the line, long distance charges may apply" prompt and then the call connects, however, when I add 1 to the number, it instantly connects the call, without any additional prompts or "warnings".
03-23-2015 12:00 AM
@Griff It appears thought only incoming calls made through a VoIP phone are impacted. Contrary to what I stated earlier, not ALL incoming calls are impacted - only the ones made through a VoIP service.. like Vonage.
03-22-2015 11:35 PM
03-22-2015 11:27 PM
Just did a test call - incoming and outgoing - to my S3 mini with Public to make sure I wasn't having the same issue, call went through normally and numbers displayed seperated without 011.
@Vostok did you email Public Mobile about the issue?
03-22-2015 11:17 PM
I'm having this exact issue on my Android phone. All incoming calls show 011, followed by the actual phone number. Didn't have this issue with any other provider I've been with in the past and I haven't made any changes to settings on my phone. Also, outgoing calls show the entire number together like 6041234567 as opposed to (604) 123-4567 when I was with other providers.
03-22-2015 11:03 PM
03-22-2015 10:41 PM
I started noticing this from last 2 days. Earlier it was all fine.
My saved contacts alway had country code in front of phone numbers. I will need to figure this out its root cause. I don't recall of doing any changes to my phone as well lately.
03-22-2015 10:40 PM - edited 03-22-2015 10:41 PM
@Martin
Alright let's forget that option then. Maybe it's brackets around the phone numbers? If they had been imported from a microsoft account or something along those lines, being a Windows phone
03-22-2015 10:36 PM
03-22-2015 10:32 PM
The thread I'm looking at here suggests that it stems from adding contacts in with paranthesis/brackets around their phone numbers. Perhaps that's why?
03-22-2015 10:28 PM
I have Nokia Lumia 635.
03-22-2015 10:08 PM
Hi @VK
I've never had that happen on my Public Mobile phone but I googled your problem and I found a few other related posts. A person in one thread suggests that it might be an accidental setting was turned on called "Dial Assist".
What type of phone are you using?
03-22-2015 10:05 PM
