2 hours ago
I try to redeem my points but the website makes it virtually impossible to do. Is that by design ? I have used Public Mobile for years now, but this website is seriously BAD ! I question my loyalty to the brand now.
2 hours ago
@Naloe wrote:I try to redeem my points but the website makes it virtually impossible to do. Is that by design ? I have used Public Mobile for years now, but this website is seriously BAD ! I question my loyalty to the brand now.
I wouldn't blame PM and slow internet speeds is certainly not a reason to question your loyalty. It may just be your equipment --- perhaps a little older computer, internet speed not up to par etc. Perhaps it would help in general to not only clear cache but also to reboot your internet modem. A simple way to reboot your modem would be to just unplug it and plug it back on in 2 to 3 minutes. Good luck.
2 hours ago
Website speed is ok to me
Try a different browser or better use the App. App loads much faster and usually less 2FA problem once you marked it Remember device
2 hours ago
This website does have its issues.
You may want to try a different web browser, clear cache or incognito mode. Or you could use the PM app.
At home, with high speed internet and a newer laptop or PC, I have no issues with website speed. At work, with slower computer and internet connection, website does lag at times.
2 hours ago
The website has some caching issues, try the App.
