Why is only 3G working on my phone
March202000
20 REPLIES 20
Not sure what’s going on but my self and my son both have same plans and both run iPhones and we BOTH are having same problem.and my other son has a different plan and using a iPhone and his lte works.and I will add all phones are beside each other on table all public mobile and 1 will show lte and other2 are 3G.also all phones set on lte
@samk10 wrote:
on the $39/80gb plan so 5g should work.
The plan that you're on makes no difference.  All Public Mobile plans give access to the same networks.
hi @March202000 you can try your sim card on another phone and it will refresh your account too
but if that does not help, an account reset by agent will be needed then
March202000
Network reset didn’t work.so I have to wait for my ticket to get answered to do a service reset?
hi @samk10
there is no active outage in NB:
https://www.telus.com/en/nb/outages
So, you need support to refresh your account
samk10
Area is northeastern New Brunswick and I don’t have 5g on my phone but I do on an iPad so I’m trying that currently.
hi @samk10 what area? and you tried 5G?
if same, ask support to fresh the account
samk10
Spoke too soon. Just lost signal and it came back as 3G again.
hi @March202000
Open Settings
Select GeneralSelect Transfer or Reset [Device]
Select ResetSelect Reset Network Settings
Enter your passcode if prompted
Select Reset Network Settings to confirm
March202000
I phone 12 mini
samk10
Settings > General > Transfer or Reset iPhone >Reset > Reset Network Settings
Edit: that’s on iOS18 and it might look a little different if you’re on a lower OS.
hi @March202000
depends on the phone, what phone you have?
March202000
How do I do that?
samk10
A network reset fixed it.
HI @samk10
ask support to refresh your account and it should resolve
or another possible fix is to Reset your phone.
samk10
Having the same issue with an iPhone SE2.
hi @March202000
so, you tried changing network mode to 4G or LTE? and no luck?
did you try switch the sim card to another phone?
if same, ask PM support to check.  please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
March202000
Tried all of that I am using a iPhone and my son has a iPhone also with same plan and his LTE is not working also,but my other son has a different plan and a iPhone and his is working!
@March202000  Have you tried to reboot the device ? Or try SIM card in another phone ? Can also try reseting network settings also see if the helps
hi @March202000
what phone do you have?
