Why is coverage in North Welland also non-existent?
03-30-2023 01:54 PM
I literally can't make or receive a call. Data? If I'm really lucky and keep the phone within a 1in square perfect location, I might have data access for 5 seconds. The problem isn't my phone. Change to a different provider?
Service
04-02-2023 10:12 PM
@asdfi21389 wierid. there is a 4G tower right at Woodlawan and S. Pelham Rd area, your data should be ok
With voice, the 3G towers are further north
try to Reset All networks on your LG phone and see if it helps
Also, ask any friends if they have Bell/Telus/Koodo/virgin/Lucky and see if they have any issue with LTE data or voice
04-02-2023 09:44 PM
Slightly better without LTE but still useless. LG G8
04-02-2023 09:34 PM
The issue exists with multiple makes and models of phones.
04-02-2023 09:33 PM
Sumbler and S. Pelham Rd.
03-30-2023 02:21 PM
03-30-2023 02:08 PM
Welland should be covered by cell coverage. I've had issues with my iPhone where my data & cell coverage would just stop, not because of the cell reception but because of the iPhone. I would restart my phone and it would start working again.
Try restarting your phone, and if that doesn't help try re-inserting the sim card and see if that may help.
03-30-2023 02:05 PM
@asdfi21389 Welland Ontario? According to the coverage map, it has LTE and 3G there
Try changing the Preferred network type or network mode to 3G and see if it helps
Also, what kind of phone do you have? model and brand?
