04-02-2023
07:06 PM
04-02-2023
10:21 PM
computergeek541
04-02-2023 08:46 PM
- Purchase a PM SIM
- Login to PM Activation page: https://publicmobile.ca/en/on/portal/activation
- If you are porting your old number over to PM, keep your old SIM in your phone and reply to the text with YES confirming you are porting over to PM. You have 90 minutes to reply.
Old SIM will continue to work for about 1 hour until porting is completed. Power off phone and swap SIM cards and power back on.
- Or you can pick a new number
- Complete to page 4 Payment section
Welcome to PM!
04-02-2023 08:40 PM
@Osa0212 you need your email and PM # to regrate the account. Go to my account in the top corner.
04-02-2023 08:40 PM
if you activate yourself online, you should have My Account setup already
However, if you activate instore before, then possible, your My Account was not setup yet
Either way, open ticket with PM support as "Forgot Password" type of ticket and Pm support will sort it out, will setup one if one is not setup, or help reset password if an account already setup
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
04-02-2023
08:32 PM
04-02-2023
10:19 PM
computergeek541
How do I setup my account?
04-02-2023 07:13 PM
@Osa0212 Try dialling 1-855-4PUBLIC.
https://productioncommunity.publicmobile.ca/t5/Announcements/Update-Ongoing-Issue-611/td-p/963252
"Confirmed Updates:
04-02-2023 07:11 PM - edited 04-02-2023 07:17 PM
the 611 system has been glitched out for a few days now.
Supposed to be fixed by tomorrow.
added info from @maximum_gato
***** Instant top ups and RTP (real time payments)can be made at Mobil/Esso stations and Canadian Tire gas bars for a $1 fee. I have heard that they may be available at some Loblaws banner stores and MacEwans back east but cannot confirm it myself.
04-02-2023 07:11 PM
@Osa0212 try ise another phone and call 1.855.4PUBLIC
if that does not work, login to My Account to load voucher therei
if you cannot login, message PM support for help
