Why do I get call telling me talk is not part of my plan?
Junkie1357
It's weird. I seem to be able to call and receive call just fine too. I have the 35$/30 day plan
7 REPLIES 7
@Junkie1357 Hi how important is your phone number to you maybe time for a new one
@Junkie1357 wrote:
I'm trying but i was called at least 9 times just today...
I'm still not clear on what you're getting per the topic title.
You get these calls. You answer them. Is it then that you're getting a recording saying you don't have talk?
I would just block the calls anyway. I have 40 or 50 in my blocked caller list.
Edit: I get junk calls with a recording saying no ones available to take your call. Um you called me. So why bother calling me when no ones available? Block.
Junkie1357
Junkie1357
What's weird is today alone, I got calls from the following numbers at least every twenty minutes.
"01122478110378"
"01122478110319"
"01122478110331"
hycm53
You mean when you make a call, you'll listen a recording message said your talk is not part of your plan? Try dial 1 first before 10 digit numbers or dial +1 first before 10 digit numbers.
Lieux
If you can call without problem..it's just an automated message we have all for long-distance MAYBE not included...but public mobile is prepaid.
RossN
If all works ignore it
