Can us mex plan
Barryl
Is Cozumel mexico part of the Ca us mex plan
hairbag1
@Barryl
it sure is. Make sure to enable Roaming in your cellphone settings. Your cell should connect to the better of AT&T, Telcel or Movistar.
Yummy
If it is part of Mexico then it is.
