07-02-2022 07:35 AM
07-02-2022 12:14 PM
It was very easy for me to reset my password. All I had to do was enter my security question and then they sent me an email where I could create a new password. I hope this helps!
07-02-2022 09:17 AM
@shfangzhe1_ wrote:This is made so hard
did you try to Self Reset password link (https://selfserve.publicmobile.ca/forgot-password/ ) ? Just enter your email address and answer the security question and it will send you the reset password email
If you have trouble self resetting the password, you can always open ticket with PM support and try to sort it out with them:
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
07-02-2022 07:41 AM - edited 07-02-2022 08:43 AM
@shfangzhe1_ I guess it's for security reasons if you tried to many times
it resets in 3 hours if you can’t get in then get in contact with a cs agent
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
type request password reset
2. alternatively you can private message them here
